Secondary air pump check engine code.
Just did a bunch of routine maintenance on my 2006 jaguar xj8 l alternator,thermostat housing water pump serpentine belt and oil pan gasket. Ran the vehicle about half hour parked it shut it off. When I started again check engine light came on.
should I just replace the pump and o2 sensors? Not sure we're to go from here? Thank you
Joe A
05-14-2024 04:09 PM
Paulie710
09-28-2015 03:49 PM
