Secondary air pump check engine code.p414
Just did a bunch of routine maintenance on my 2006 jaguar xj8 l alternator,thermostat housing water pump serpentine belt and oil pan gasket. Ran the vehicle about half hour parked it shut it off. When I started again check engine light came on.
should I just replace the pump and o2 sensors? Not sure we're to go from here? Thank you
Joe A
05-11-2024 06:43 PM
