Serius Radio removal
I don't subscribe to the Serius entertanmnet service, so I would like to remove the factory installed Serius tuner that takes up a position where other cars without it have an ashtray. I have already purchased a used wood covered ashtray module. My issue is how do you remove the presently installed Serius unitl? I was able to unsnap but only partially lift the black face panel because complete removal is restricted by the length of the cig lighter base. Underneath the faceplate, I can see that the tuner is pretty welll fixed in place. Am I using the wrong approach to remove the unit or is it permanently fixed and an attempt to replace it with the ashtray module not an available option?
I removed the Serius system on my 05 car. You definitely need to remove the center console to remove the head unit and replace the ash tray assembly. There are a couple of good write-ups on this forum on how to do that. I removed all the modules in the trunk as well. That's not necessary but I would at least de-power them. This project should be no problem for anyone with basic mechanical skills.
Good Luck
Jeff
Good Luck
Jeff
Blairware
10-29-2014 02:08 PM
