Serpentine belt $950----yikes!
Dealer says I need a new serpentine belt but it is now discontinued and the only one available is a new design that requires replacement of all the pulleys at a cost of $950. They are going to check with the warranty, but do not believe it is covered.
Any suggestions?
Any suggestions?
Here's the break down: $500 labor, $160 for 2 belts (did not realize there is a serpentine belt AND a supercharger belt), $290 for a pulley, tensioner & bracket so really it is the labor that makes this an expensive proposition. They're going to file a warranty claim with the extended contract, but even Jaguar would not cover it because I brought up the TSB 3 years ago and was told it was not warrantied.
Sadly the problem I have run into is that Jaguar discontinued them and redesigned the pulleys. No one has the old belts so basically it is going to cost almost $1K to change the belts.
I remember when the TSB came out 4 years ago or so and Jaguar would not cover it under factory warranty, the dealer service of course said don't worry about it.
So here I am now with glazed belts and non available. Isn't there some sort of trade policy that stipulates manufacturers have to support the products they make?
Strange the dealer would have said that. Those setups were replaced under warranty on many cars and i've even done them on Rovers. The supercharger is scheduled to be replaced at 100k and the main belt at 150k. I've not seen many last that long due to cracking. The latest bulletin for SQUEAKING came out in 2009 and updated everything like you said. They may not cover it cause the car it "out of the VIN range" i don't know as I don't work there.
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
