SHAKING
Old 01-15-2016 | 04:43 PM
smatt61's Avatar
Default SHAKING
Hi all when going at 50 mph the car starts shaking and looses power not go over 50 mph intrying to do so the shaking gets worse is it a sencer ????
Old 01-15-2016 | 04:45 PM
smatt61's Avatar
Sorry my jag is a xj8 3.2 year 2000
Old 01-15-2016 | 04:57 PM
cjd's Avatar
cjd
Power on and off, or only power on? If it is an engine is-fire, it will only be power on and it will generate a code. Always start with the code.
If it is power off too, then we need to look at wheels/tires/drive shaft.
smatt61 (01-15-2016)
Old 01-15-2016 | 05:03 PM
smatt61's Avatar
Sorry what do you mean power on or off do you mean throttle??
Old 01-16-2016 | 04:48 AM
JagV8's Avatar
He does. And is-fire -> mis-fire (misfire).
Sounds likely to be bad coil(s). Worth looking in case dirt/water/oil on any of them / in plug wells.
smatt61 (01-19-2016)
Old 01-16-2016 | 09:51 AM
mberman's Avatar
Check your air filter. It may need changing and starving for air at highway speeds.
Also check for any DTCs.
Old 01-16-2016 | 05:18 PM
Fraser Mitchell's Avatar
Try posting your message in the X308 forum, the one for your car. You should get a response from more people.
Rudun
01-20-2016 10:34 PM
bostongrun
01-16-2016 09:32 PM
AirCommando
01-16-2016 03:19 AM
Jason Souhrada
01-13-2016 05:24 PM
ScottAles
XK120 XK140 XK150
01-13-2016 10:29 AM
Quick Reply: SHAKING
