Shifter Behavior
I've just noticed that the shift lever does not hit the bottom of the gate in drive. The tranny seems to be in drive, but the shift lever stops about 1/4" before hitting the bottom of the slot. I looked at the cable bracket underneath and it is secure. The lever will go around the left into the J gate as it should. Just curious if anyone has an idea on this one? I have never heard of this before.
Well, I pulled the surround and looked into it. As I thought, a large piece of plastic debris was blocking the shifter from seating in drive. It looks like it has been broken awhile, the broken edges were dusty. I removed it with a long nosed tool and all seems well. This broken piece is part of the housing which includes some kind of ramp. the shifter works normally, so I'll try to forget about it.
n2audio
17
10-09-2015 10:53 PM
