shock failure on 2004 xjr
Hi paceconsul,
Welcome to the Jaguar Forums! It's great to have you with us.
I have moved your post from the forum for the X308 to the forum for the X350, which is the Jaguar factory project code for your 2004 XJR. Here you will find knowledgeable owners of similar cars.
There is a lot of existing information on the forum on the subject of the air suspension. A summary of the system can be found here:
Air Suspension & ECATS System Summary: Components & Operation
Without more details it's impossible to know if your problem is an uninflated air spring bladder or a failed shock absorber.
Does the suspension inflate properly and does it sit at the correct ride height at all four corners? Do one or more corners drop down overnight?
In the meantime, please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Cheers,
Don
dieselmedia
23
03-14-2018 03:41 PM
pcmos
36
02-04-2018 12:11 PM
abonano
11-02-2017 08:49 PM
nellerbeck
41
03-30-2014 11:08 AM
