smartphone bluetooth connectivity with Jaguar
Old 07-05-2016, 06:40 PM
klintous's Avatar
I am so happy with the iSIMPLE ISFM2351 TRANZIT BLU HF and it fits any car.
Old 08-28-2016, 06:46 AM
Rapunzil's Avatar
I'm hoping to find a way to use my iPhone 6SPlus with the existing system in my 2006 XJ8.
I called Jaguar customer service and they said that the Jaguar Voice phone/bluetooth option is only compatible up to iPhone 4.
Is there a way I can upgrade it? I don't want to have to plug anything into my cigarette lighter, and I would like to be able to just use the voice button on the steering wheel.
Old 08-31-2016, 09:37 PM
Acer721's Avatar
Originally Posted by collector
Guys, I bought for 100.00 the new updated Bluetooth module and replaced the antenna and the box and now the Bluetooth connects immediately, even when I haven't started the car. The pairing is also just as fast. In 08-up, they had a revision and the revised box is the one you want. I sold the one that came in the car for 100.00, so I broke even. It pairs up so fast that all I do when I get a new phone go into Bluetooth settings on my phone and it finds the Jaguar car instantly and then I put in the 4 digit code and its paired. No more of that messing around trying to make it work. I did that last year and it holds as many phones as you can connect to it. I have a IPhone 6S and my wife has a Galaxy 7 Edge and they are instant hook ups. Find a wrecked car and buy the module out of it. Trust me its worth the effort.
Is this the module you were talking about? Newer Factory Jaguar Bluetooth Phone Module Kit for s Type x Type XJ8 XJR VDP | eBay
Old 09-01-2016, 01:16 PM
SailorSam's Avatar
Default Mine works...
My iPhone 6 Plus works in the X358.
Mark B.
Old 09-04-2016, 08:01 PM
jackra_1's Avatar
Received 1,756 Likes on 1,327 Posts
Originally Posted by Acer721
Thats the module I installed but for a heck of a lot less! I bought fiber optic cable and a microphone as well as an antennae separately on Ebay.
Someone wanted a picture. What you are looking at is the rack unscrewed and up ended so you can see the back.
On the bottom is the Bluetooth module, next one up VACM( Voice Activated Control Module), next two are NAV and CD changer.
All power connections were already there, just taped flat against the harness.
I was wired for ICE ( In Car Entertainment) and that was simply looped with a short fiber optic cable. All the fiber optic cables were marked with yellow tags.
This is an "old" view as I have since replaced the kluged cable antennae with a BMW antennae that was mentioned in this forum.
Attached Thumbnails smartphone bluetooth connectivity with Jaguar-p1180148.jpg
The following 2 users liked this post by jackra_1:
Acer721 (09-04-2016), Datsports (05-30-2018)
Old 09-07-2016, 01:50 PM
Rapunzil's Avatar
I would be most appreciative if you could tell me how to pair my iPhone 6S plus with my 2006 jaguar XJ8. I tried looking in my manuals and couldn't find anything. Thank you so much!
Originally Posted by philc850
I have a 2007 XJ Super V8 and the factory bluetooth connects instantly to my iphone 6plus. You can pair the phone (only 1 phone at a time but you can replace any phone with another any time). You can also download your phone book from your smartphone into your car's phone directory. Let me know if you need help on how to do these 2 things.
Old 09-08-2016, 05:20 AM
SailorSam's Avatar
Try this...
Mark B.
File Type: pdf
  #28
Old 09-09-2016, 08:16 AM
Rapunzil's Avatar
Thank you!
Old 09-09-2016, 10:29 PM
Jroot's Avatar
Default What do I need
I have read all the posts in this thread and I am still confused as to what I need to take my 03 XK8 into the iphone age? Can anyone explain to me what I need to do to get my iPhone6s to connect over a Bluetooth connection to the built in audio system?
  #30
Old 10-11-2016, 01:20 PM
apgwales's Avatar
well my xj connect fine , but no music !
so in line fm modulator 2.5 mm jack now have aux port.
  #31
Old 10-11-2016, 05:27 PM
JagLover50's Avatar
Default bluetooth connection
Acer721 where do i get this part and what is it called?
thanks!!
  #32
Old 10-13-2016, 06:43 AM
apgwales's Avatar
Hi Acer721,
Bought off ebay link below. Simple to fit, power supply and connect to radio aerial input. JAGUAR Car AUX In Veba FM Radio Modulator & FAKRA Aerials for iPhone MP3 Devices | eBay
  #33
Old 11-14-2016, 10:14 PM
Eric300hk's Avatar
Default Bluetooth
Would you please give a bit more details how to connect them..own my car for 8 years and never use it..an electronic dumm !
  #34
Old 11-16-2016, 05:42 PM
SailorSam's Avatar
Try post #27 above. I put the instructions there.
Mark B.
Eric300hk (11-16-2016)
  #35
Old 12-02-2016, 07:07 PM
JagLover50's Avatar
I have a standard 2004 xj8.. no gps big screen.. can you please help me.. how do i get my iphone 7 to work? i am so clueless where and what to buy and i dont want to get ripped off
thank you
Mrivera (01-02-2021)
  #36
Old 01-16-2017, 10:38 AM
Benj628's Avatar
Would like to get bluetooth in my 2001 XK8 Conv. and after reading this whole post I am still not seeing much for a direct explanation on how.
  #37
Old 01-17-2017, 11:10 AM
SailorSam's Avatar
I have done this - with the help from many others' posts - in my 2000 XKR.
I used this eBay item: 182404216360
https://www.jaguarforums.com/forum/x...2/#post1513494
Kind regards
Mark B.
Benj628 (01-17-2017)
  #38
Old 03-02-2017, 07:31 PM
Rossignol's Avatar
Default thomash85715......
Originally Posted by thomash85715
Thank you to all who have offered information on this so please forgive ignorant questions. I do not fully understand the difference between Bluetooth capability and pre-wired phone capability. My 02 Xtype book showed pictures of a phone fitted into the console which was not present when I bought the car used. My present 04 xj8 seems to have newer setup for pairing with any external phone via Bluetooth. Are these two completely different systems for talking on a phone in a jaguar? If I took pictures of rear chamber of my car and its empty wiring plugs, will that help determine what exact box I need? If I push a phone command button now, screen says PHONE NOT FITTED same as the 02 screen would say. If someone who has a working factory Bluetooth system with nav screen and cd changer in boot would post image of their rear chamber with the connectors showing, that would help me a lot before I spend money on a box that might not work in my car.
I have the same vehicle, 2004 XJ8 VDP w/ nav and the cd changer in the trunk..... i would love to know if you ended up with a working Bluetooth system that allows the use of the steering wheel controls and factory speakers with the latest iPhones
  #39
Old 04-30-2017, 07:17 PM
biomike's Avatar
Default Phone Connectivity 2005 Jag
Thank you guys for the Jag Directory page. I entered the last six of the VIN and entered the code##3#*# then send and I was able to pair the cell phone! Very much appreciated. Mike
  #40
Old 05-18-2017, 02:46 PM
yusoslo's Avatar
How can I get bluetooth streaming for music in my 2004 Vanden Plas with Alpine radio? I heard some cars you can tap into the CD changer in the rear. Worst case I want to at least have the AUX jack so I can listen to music in the car. Thanks.
Quick Reply: smartphone bluetooth connectivity with Jaguar
