So finally it's my turn on "lowrider" stance...
That's funny. Mine blew that strut too, did yours leak out the oil all over the wheel? Eventually you'll find it sitting completely on the ground...
I did arnott rebuilts for both of the front struts. I did them at my shop, but with the value of these cars, and arnott's lifetime warranty, I don't think a 2k+ investment in suspension makes sense when it can be done for less than half.
Take care,
George
Take care,
George
I haven't found any oil leak yet. What it does is when it's siting like that, and I proceed to start up the car, it'll pump up to a certain level and then once it pass a certain height and you'll hear the hissing sound and car car will be dropping slowly despite the pump is still running.
When the bag blew we just park the car and me and my wife heard the sudden hissing sound like the air purging sound but this time it's couple times louder and couple times longer. Regular purging sound is more like 0.2-0.4 second type of purging but this time it's like purging for 2-4 second type and that corner drop down pretty rapidly, and a moment later the driver side dropping too I'm guessing the car trying to maintain the ride height and balance and the dash came up with the fault message and light at that moment too.
Order the shock thru Arnott today and should be here in a few day. Luckily it happen now because this weekend I have a 600 miles roundtrip drive and guess it'll be the wife's car instead of my Jag.
The shock is a pretty straightforward swap. Make sure you disconnect the battery and then restart the car once everything is back together. You may get an air suspension fault at the first startup cycle because the resevoir will be empty, and it may take the compressor more than the 300 second threshold they have allowed to get the car to operating pressure. (That's what 90% of the air suspension fault errors are especially when it's cold out). It should go out on the second start cycle.
Take care,
George
Me too on a 04 xjr
I just did the same and picked up my car this afternoon, also changed the front shocks with the Arnott rebuild sport shocks (lifetime guarantee) had them installed at my dealer. Its running a little high, after shutting off the motor it does not drop the normal 1 to 2 Inches (FYI mine never dropped to the low rider stance, just a bad shock). So from what I understand drive it for a few days and it should just level out?
aholbro1
08-05-2021 05:02 AM
abonano
25
09-25-2015 10:43 AM
