sorry but another air suspension ?????
my mothers car [an early 04] is completly lowered ---comp. runs for a few minutes then stops after a minute or so starts cycle again ---suspension does,nt rise --------i think might be air leak near comp.---------my main ? is she called me said she had amder light ----air susp. fault ----i told her be careful --look put for red light air ride low -------------will see it after work ---when i see the car it,s all the way down ---but has no ride hight message and still doe,nt ---the lack of message worries me -------thanks in advance
Sounds like a classic air shock leak, but could be line related also. Check the lines at compressor and the manifold under the spare tire near the pressure tank. Soapy water in a spray bottlle would be my first diagnosis step. Get all your areas ready for inspection prior to starting as the compressor will only run & cycle for so long. Other members will have more advice, as i am only going off what i've read previously. My air suspension has had no issues.
There are dozens of suspension threads to review if you need immediate information retrieval and theories to ponder.
1 problem fixed bad front driver strut ---stole 1 from my spare car---the thing that scares me though is that the car never got a red light --car to low message --anly the amber --air suspention fault light----------but now my second xj is a low riber -----------thanks for the responce ----nice big xj you have
philwarner
25
06-26-2021 05:43 AM
scooternva
19
10-27-2015 02:14 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
Andrew Fanshawe
09-14-2015 07:40 PM
