Special Tool: Wiper Pivot Arm Removal
The following 3 users liked this post by Coventry Foundation:
Many thanks, Coventry Foundation!
Do you have a presence in the PNW of the U.S.(Seattle)?
I think the Amazon one will work. I'll dink with the measurements &, assuming I don't find something in my toolbox or at Harbor Freight that will work, I will order it. If necessary, I can modify the base.
The Foundation has 2 tool loan sites. One in the east and one in the west (CA). JCNA has a good club in your town. Look under www.JCNA.com
04Xjrsteve (03-11-2024)
Steve,
I used the type you have shown to eventually successfully remove my X350 wipers.
Can be a bit hard to span to the centre of the drive shaft though, and I will add that I felt I needed to hold it in place to stop it walking.
They can be on there really tight and I did put some penetrating spray on beforehand. Honestly thought that puller was going to let go before it managed to pop the wiper.
I had one in my tool box that was adjstable in all directions & had the bottom of the wiper arm been flat and not curved, it would have worked. I am going to put some PT Blaster on them & try again. I will go by the parts house and look at the pitman, etc.
BTW, I was a member of the JCNA until 2007. Had forgotten all about it, but it was a very nice experience. Will contemplate rejoining.
Thanks for all of the help!
I've never found that type particularly effective and often there isn't sufficient clearance to use it.
After a long search a few years ago, I found this at a tool specialist and it's never failed.
Exactly the same one is now available on Amazon under various different brand names.
The following 2 users liked this post by GGG:
04Xjrsteve (03-12-2024),
motorcarman (03-13-2024)
1jagoff
07-30-2010 07:20 PM
