Squealing Brakes
#61
I went through the same thing could not get the breaks to stop squeaking, replace all the same parts he did. so what i ended up doing is replacing the rotors with drilled and slotted rotors and use a ceramic break pads. the sqeel is gone. the new rotors that are drilled and slotted get rid of the heat better. it could just be the rotors are getting too hot. if you go this way make sure you follow directions on how they go on. hope i can post this here but i got the parts from here Performance Brake Rotors | Brake Pads & More Brake Parts | Cquence.net
#62
If that's the only shim you have it's in the wrong place and will never work as intended...
XJ8JR , get rid of what ever crappy brake pads you have fitted , most pads that are noisy don't have the proper steel shims supplied , I would suggest you buy AKEBONO pads , they cost a bit more but do have the steel shims fitted...
BTW , that rubberized shim is designed fit in between the disc pad and the steel shim...
Upon further research, I'm seeing that some people complain that ceramic pads make noise compared to OEM semi-metallic.
#63
#64
#65
I just purchased new brake rotors and pads. I purchased Brembo rotors and Brembo ceramic pads that are specified for the normally-aspirated XJ8, i.e. they are not XJR Brembo parts. I found rear rotors and front pads at Import Replacement Parts (www.importrp.com). I found front rotors and rear pads through Amazon. I could not find any one supplier to provide a complete set/kit of Brembo rotors and pads. These parts should all be here in the next couple of weeks. I will let everyone know the results. I'm excited to see if these Brembo parts truly exceed the OEM specs and stop the squeal. After a lot of OEM research, it appears that TRW supplied OEM pads and rotors. Mintex also supplied Jaguar with parts. However, it's difficult to find one supplier that can provide a complete front/back set of matching OEM brand brakes; aside from the dealer of course. The Jaguar dealer prices, even those operating through eBay are very expensive. I'm not quite sure why the front TRW rotors are so expensive (found one set of genuine OEM on eBay), but you can find front and rear TRW pads for cheap on Amazon.
#66
Regardless of my noise issue, I am unhappy with the feel of the drilled/slotted rotors and ceramic pads. I'm considering going back to blanks and semi-metallics. I don't really care about the extra dust as I wash the car every week anyway. I just want whatever will give me the best bite and feel. My girlfriend's Infiniti's brakes make the Jag feel like an old jalopy. Am I correct in assuming that OEM pads/rotors will restore that bite and grip?
#67
check out the site I posted and go to how to section. This section might give you some help.
Don't know if it will but it is worth a try before spending more money on the repair.
#68
Did you ever try the Jaguar brake caliper grease that is specifically for this issue? I had the problem on my car, bought the grease and applied per the TSB, has been gone for almost a year now. Grease goes on the back of pads, and where the pads slide (any metal-metal contact point).
#71
Looks like the grease is for a creaking noise on the MY2006 and above. My noise is the more common "creep groan" that happens just before the wheels top turning, depending on braking conditions. All cars do it to an extent, but it seems like the Jag does it all the time. I suspect the ceramic pads just don't grab the rotors enough.
#72
#73
I also get the creep groan when applying the brakes at low speed and coming to a stop. I also have semi-metallic pads. So replacing your ceramics isn't going to solve your problem. I've also been reviewing your list of work. Have you done anything to the rear brakes? I was almost positive these issues were with my front brakes until I diagnosed the problem outside of the vehicle with another person driving. The squeaking and chirping was happening at low and high speed at front and rear wheels. I wouldn't think this a problem with wheel bearings. So, not only am I waiting on new Brembo pads and rotors. I will be ordering rebuilt calipers. It is very likely that more than one caliper is hanging up (not retracting).
First, I have had someone outside the car listening, and it does sound like its coming from the front, but it is admittedly difficult to tell.
Second, every time I have fiddled with the fronts, the noise has disappeared for a short time. I would imagine that if it were the rears, my efforts would have no effect whatsoever. On separate occasions, I have fiddled with the rears without touching the fronts and have gotten no results at all.
I have bitten the bullet and ordered new front wheel bearings, blank rotors and Bendix Titanium semi-metallic pads. I would prefer to test each item separately to see if I can find the direct cause, but I'm so tired of taking everything apart, I just want to do it all at once. Even if the new pads and rotors don't take care of the noise, it'll still be an improvement for me, as I can't stand the set-up I have now. And at least I'll have new wheel bearings too.
#74
I decided I couldn't wait, so I installed the new wheel bearings/hubs and the pads last night. I haven't received the new rotors yet, so that will have to wait until next week. I can immediately feel the difference with the semi-metallic pads. The brake feel and response is SOOO MUCH BETTER than ceramic, and they haven't even broken in yet. No creep groan or squealing yet, but it's still too early to tell if it will return. Will update, but so far so good.
I don't really feel any difference concerning the new bearings. I guess my old ones were still good.
#75
#76
Does your car have anti-rattle springs? When I purchased my used XJ8, there weren't any springs on the car. I just assumed they weren't supposed to be there. But when I search the web, there appear to be springs available for the XJ8. I'm curious if these springs would help keep the pad from squealing when the brakes aren't applied. I know another user asked this question. I previously replied that not all VIN's specified springs, but I'm wondering now if they should be on there.
#77
After driving all over town over the weekend, I can confirm that the squeal has been reduced by 95%! There is just a small cyclical chirp now when rolling to a stop. I can live with that so long as it doesn't get any worse!
I still will be installing new blank rotors today because I don't like the feel and the noise/vibration of the drilled/slotted ones I have on now. Perhaps the blanks will get rid of the cyclical chirp.
I'm loving the Bendix IQ pads so much, I've ordered a set for the rears. No more ceramic pads for me.
#78
#79
UDPATE: 3 days later and still no squeaking or squealing. It seems the new rotors got rid of the cyclical chirp that I was still getting. HOWEVER, now I'm getting really nasty creep groan just before coming to a full stop. I'm hoping that'll change once the rotors wear in a bit. Either way, I'd much rather deal with creep groan than screaming nails on a chalkboard.
#80
UPDATE: A few days ago I started to get a squeal again when riding the brake to a stop, along with the continued creep groan. Per a suggestion on another thread, I flushed out the incorrect Class 4 brake fluid and replaced with a Class 6. Not really to see if it would help, but just because I discovered that the fluid I had in there was below spec.
The fluid change went well, pedal felt strong, but still had the low squeal. So I decided to try a proper bed-in procedure. Braking felt soft all the way home because of heat fade, but there was no creep groan at all. Coming to a stop was nice and smooth.
Well, the creep groan returned this morning, along with an even LOUDER squeal, AND braking power still feels soft. So, it looks like the bed-in procedure made things worse. At least temporarily, I hope. I'm praying they just need more time to fully break in. I'm going to give them a few hundred miles and report back.
I am getting really tired of this problem. All I want is smooth, quiet braking. Is that really too much to ask?
