Stage 1 air intake tubes now available.
#161
#162
#165
#166
Don B (06-05-2019)
#169
Stage 2 project has been shelved due to issues with companies that create carbon fibre parts and generally being messed about but yes the original concept was to have this as an add on to the stage 1.
#170
To order send me a pm with your location and we can go from there.
#173
#174
Received 12,948 Likes
Hi bikerad,
I'm not sure if this still works since the forum masters changed the "Thanks" function to "Like," but when you Like another member's post it may count as a post for you (at least it did when the function was Thanks). So it might be worth visiting some threads and Liking some posts you find informative. Your post count may grow accordingly. If not, you haven't lost anything and you've encouraged other members to continue to make the effort to post helpful information.
Cheers,
Don
Cheers,
Don
#177
#178
I need to reread the posts. Is there a straight change from the factory pipe to this one that shows Dyno performance? Better looking is good. Blower whine might be okay. Not convinced the stock pipe is an airflow bottle neck.
I might change the pulley. Low end grunt is where my XJR could benefit.
We have a turbo charged BMW and this blown Jaguar. That year model BMW used two small turbos to feed 3 cylinders each. Hits max torque at 1500 rpm. Feels like a supercharged engine.
The Jaguar seems to wind a little higher before the boost kicks in. Feels like a turbocharged engine.
With my driving habits, it limits the high rpm excitement.
#180
Dear Sir,
can you ship Stage 1 air intake tube to Germany for my 2008 Daimler X358 ?
Please contact me at tahomacol@hotmail.com
Regards
Foxhunter
Regards
Foxhunter
