started it but now the suspension
Old 09-25-2015, 04:58 AM
driver safz's Avatar
Default started it but now the suspension
hi everyone i have a 2.7 tdvi xj had a wiring issue i fixed that got it running all cleaned up ive noticed its pulling air suspension fault, the rear end of the car is raising too high ps help what can it be? thanks saf
Old 09-26-2015, 06:01 AM
Fraser Mitchell's Avatar
Received 2,451 Likes on 1,949 Posts
You need to get the stored fault code(s) read for this. The system is detecting something is wrong, so this shows the ride height transmitter is functioning, but something is not responding to its inputs. Could be a stuck air valve in the valve block assembly, but until you know what is going on, its difficult to know what else to advise.
Edit
Just remembered there are two ride height transmitters at the rear. One could have failed or been displaced. Where was the location of this wiring issue ?
trosty
26
12-18-2022 06:40 PM
GordoCatCar
01-02-2017 01:10 PM
Harry Dredge
09-03-2015 03:04 AM
Harry Dredge
09-02-2015 02:26 PM
Quick Reply: started it but now the suspension
