Starter plus inflate struts
I believe my starter needs to be replaced, but I'm unable to get enough torque on the top bolt of the starter to turn it (space is just too cramped) and will probably have to have it towed into the shop. Has anyone gotten this bolt off before and could let me know how you did it?
It's the topmost no. 1 that is in a recessed spot that only a short ratcheting wrench can reach. But too stuck and not enough leverage room for torque.
Unfortunately, since she's been sitting for a couple weeks, the struts have deflated. I'd rather have her not sitting so low for a tow - is there a way to inflate the struts without having the car running?
Regarding the starting problem, I started troubleshooting by replacing the battery that showed bad, so the battery is brand new. Are there any other obvious things that could be bad? While the electronics all light up, there's absolutely no movement in the starter itself. I had about two instances on different days of that happening when I tried to start. Then after the second instance, the next morning the starter was dead. Thanks for any help!
An old school trick is to hammer the starter while turning the ignition. You may get one more shot out of it, enough to get the struts inflated and drive it to a shop.
Really no way to get the struts to inflate w/o having the car running short of hot wiring the compressor to run but I wouldn't even consider it an option...
Another issue you may have IF you car is the same as mine you have to remove the engine support on the starter side to be able to maneuver the starter motor out.
That means raising the engine on that side.
Have you checked the related fuses?
With the correct extensions and swivels I had no problem in removing the nuts and bolts off although the top most was mostly by feel.
I have done this several times because of getting new starter motors that were incompatible despite claims to the contrary.
I was unable to find a rebuild shop that would accept my original to rebuild.
Well, I am ever the novice. Thanks for the reminder to check fuses, jackra_1. It was a blown 25 amp solenoid fuse in the engine compartment. At least I didn't succeed in putting in the new starter or tow it so the mechanic could find the blown fuse (or worse not find it). LOL
Should I be concerned about why the fuse blew and be checking that out?
I have an i930 icarsoft which reads Jaguar codes. I believe there is a more recent upgrade to this. Not sure however mine has proven very useful.
you are lucky, I have the same tool and it does not do much.....wont even read old codes.......tells me 2004 car is incompatible............of course.......Ive had no joy from icarsoft as to either replacing the whole unit........or some sort of download.....which it will not do.......tells me update is not available if you use apple products.....?????
Id like to get my Money back....but absolutely no response from Icarsoft at all.......been over a year now...........
ANYONE THINKING OF BUYING THIS TOOL.........DONT BUY ICARSOFT........SOME WORK AND SOME DONT.......AND THERE IS ABSOLUTELY NO CUSTOMER SERVICE.
mr bill asheville
06-30-2018 05:36 AM
4thjagandstillgoing
02-26-2018 05:20 PM
joenglishgirl
06-23-2013 06:07 AM
ehaglund
10-18-2012 12:29 PM
