Starter removal
Old 12-26-2017 | 10:09 AM
talashek's Avatar
Default Starter removal
My 2004 xj8 starter crapped out. Where is starter located and is it difficult to remove?
Thanks, Tom
Old 12-26-2017 | 10:48 AM
jackra_1's Avatar
If it is like my 2005 XJR it is on the passenger side bottom rear of engine just rear of the alternator.
I had to remove the engine support bracket to get the alternator out and you may have to do the same to get at the alternator.
Old 12-26-2017 | 11:25 AM
Box's Avatar
Box
JTIS does not state that anything need be removed in order to R&R the starter. Remove negative cable from battery, remove leads from starter, remove bolts and remove. Reverse to install.
Old 12-26-2017 | 11:59 AM
jackra_1's Avatar
That is good news.
Old 12-26-2017 | 12:21 PM
Rivguy's Avatar
That is good news. The starter in my Northstar V8 Cadillac was located underneath the intake manifold! Eventually I had to replace two starters over the time I owned it. It seemed like a dumb place to locate a starter, but the factory claimed it prolonged starter life by protecting it from dirt, moisture and the heat of the exhaust system. Maybe. I believe that the Lexus V8 and the Infiniti V8 may have a similar set up. The starter in my OHC 4.6 V8 Mustang is located in the conventional location. Believe me, I checked that out before i bought it! Happy Holidays!
Old 12-27-2017 | 07:22 AM
talashek's Avatar
Default starter removal
Thanks for the information...I'll give it a go.
Tom
Old 01-02-2018 | 04:25 PM
tampuhaw's Avatar
Hi Tom -
How did it go? I may have starter trouble myself just this morning. your findings as to the location and removal of your starter will be worth a million to me.
Old 01-03-2018 | 07:10 AM
talashek's Avatar
Default Starter replacement
Tampuhaw: It turned out to be just a weak battery. So I was spared trying to replace starter in -7F garage.
Thanks,
Tom
tampuhaw (01-03-2018)
Old 01-03-2018 | 09:51 PM
tampuhaw's Avatar
same thing with me, Tom. somehow i jumped it again this morning and the jag roared like it should. my battery is tested to be in excellent shape barely one year old read 12.25v. i still have to check the cabling connections though.
the no click at all when started several times yesterday remains a mystery and likely to happen again!
Kealan
09-24-2019 03:14 PM
JimC64
03-02-2015 09:07 PM
sjuraud
08-28-2010 03:11 PM
01-25-2007 12:53 AM
11-15-2006 09:30 PM
Quick Reply: Starter removal
