Steering Wheel Vibration Saga
I feel your pain.
The thing is, there have been dozens of causes listed, all valid. And apparently you have elimininated most of them. There is no "single cause".
May I ask the forum "what about the steering box - do they ever wear out or could cause it?" It's like, "what's left"?
Incidentally, you said you changed some control arms and the wobble became "100x worse". Wouldn't that point to a problem in the control arms or their installation, albeit not in the direction you hoped? But it's what you said, "control arms made it worse". Or were you doing multiple things at once.
Although nowadays it is not recommended to rotate tyres, I'd at least try rotating the tyres just to see what happens. New or not.
At some stage you said your brakes were a bit draggy. I can't remember if you eliminated that. My Honda Elysion has steering wheel wobble on braking, but I'm a clever b'tard and noticed it only happens when I brake...skimming the disks seems either expensive or perhaps not even available.
It just has to be one or more things already mentioned?
>>No one has an updated "what actually cured this problem" story?<<
"ask not what your country can do for your XJ — ask what your XJ can do for your country."
OnebadassXJR (07-14-2021)
