Stock Alpine amp Bridge
I really want or more over have a deep desire to up grade the stock audio system in my 2004 XJ-R. Also, sine i tool the rear deck apart to tint the rear window properly, I decided to investigate the subs mounted in the rear deck.
so, common knowledge they are 2-6 1/2" woofers at 4-ohm each
However (in my experience) all alpine amps can bridge to a 4-ohm load.
so i tested it.
Positive(+) from left and negative (-) from right.
so if the 2-6 1/2" speakers were replaced by 8-ohm drivers this is potential double the power with negligible strain on the amp![Icon Eddie](https://www.jaguarforums.com/forum/images/smilies/icon_eddie.gif)
tho i am going to chose to go a bit further. i thought this type of info my chose to be useful.
so i tested it.
benwillcox you are right
my blind ignorance...to all those of jaguar forms i owe a great apology for sullying this sight with such unfounded in reality information and will not do so again
I am sorry jaguarforums.com
if i can remove this , I shall remove this blasphemous post as soon as possible or if need be delegate it to one in power to remove it..
again
I apologize for not putting do diligence to the information i provided
again
bfsgross
05-13-2011 04:41 PM
qwiketz
07-08-2010 11:53 AM
