Strange Warning Bell when Putting my XJR into Reverse
Hi everyone. I've had my 2008 XJR for two years now and store it in my brother's garage over the winter. This past Sunday, I went to start up the car for the 3rd time since early Nov. and back it onto the driveway. Immediately when I put the car into reverse, I got what I can only describe as a two-tone, fast warning-bell alert. I backed the car 1/2 way out of my brothers' garage and put the car into park, at which point the warning bell stopped. I ran the car for about 20 minutes and pulled back in. Somewhere within that time, I also noticed that the amber engine signal had also come on. I'm certain that he alert bell when putting the car into reverse was definitely not the park distance sensor, as that also came on until the car was clear of objects.
I came back and started the car up once again an hour or so later and got that same unusual two-tone fast warning bell when I put the car in reverse. For what it's worth, the amber engine light stayed on as well.
I've searched the owners manual but can't find anything that describes a two tone fast warning bell. The sound immediately stops when putting the car into P, N, or D.
Any idea what this warning might be? Any chance it's just some unusual gremlin do the car being idle (other than having also started it in early Dec. and January) and cold?
Any thoughts much appreciated.
David
David
Minndavid60 (02-06-2013)
I accidentally discovered the precise tone you are speaking of the other day and it is indeed separate and distinct from any other chime.
To re-create this sound, try to shift into reverse while the car is off. Even without the key in the ignition, this alarm will go off.
As for why your car is doing this while the ignition is on, I really don't know. But maybe it has something to do with the ignition key position. I know my car has a very sloppy ignition that will let the key turn easily regardless of whether the car is on or not.
I suppose if the key is not in exactly the right position, this alarm would sound. Just a guess.
My car was totally encased in ice this morning, put in in reverse & got alternating tones from the front & rear park sensor speakers, dee-duh-dee-duh-dee-duh etc... sounded like a police siren from an 80's computer game.
It was because the sensors front & rear were covered in ice. After turning off the front sensors it stopped. Might be the same thing you've experienced?
Great feedback everyone! While my car is garaged and covered, it has been very cold here this winter, so I'm thinking that perhaps the extreme cold has at least temporarily played some havoc on the sensors' operation. Cambo--that sound you described sounds exactly like my sound. A low battery could also be a culprit, although I do keep a trickle charger on all winter. When I start the car in early March, I will first see if the sound repeats when in reverse and if it does, I will then turn off the sensors (I can only turn off both, I believe rather than just the rear ones) and see if that makes a difference.
Thanks everyone! If anyone has any other ideas, please let me know.
To all... I still recommend trying shifting into reverse while the ignition is off just for giggles.
I have a 2006 VDP and this particular car emits a very odd, almost angry sound when doing this.
May/may not be related but it was funny to discover it after all these months I've had the car.
My car has both front and rear parking sensors and these sound very different than the transmission nanny.
Not sure I ever closed the loop here. When I went to start the car in March (on a warmer day than when I started it in Feb.), the strange warning bell disappeared and has not reappeared. Chalking it up to the extremly cold couple of weeks spell we had prior to my starting the car up in Februrary.
Thanks everyone for your feedback. I'm experiencing a completely different issue with the car stalling in stop and go traffic and the amber check engine symbol light coming on. Will start a different thread.
