Stripped brake bleeder screw 2004 xjr
While bleeding brakes, I encountered a stuck bleeder screw on the front driver side caliper. I used an extractor socket to remove the screw and the threads were gone. Has anyone encountered this problem before. SHould I retap the port and what size screw is the proper replacement? I have seen M10 x1.0 pitch as the size, but I wanted to be sure. Any advice is appreciated. XJR uses the Brembo system.
This is a very common problem on the Brembo callipers, I had to have two replacement rear callipers on mine a couple of years ago , I was lucky to find two about 1/2 hour away, I asked them to make sure the bleed nipples were functioning before I went to collect them.
I have got a used spare front and a brand new rear now as well just in case I ever need them in the future as they are rare to find without paying £500 + each from Jaguar !
XxSlowpokexX
10-16-2019 08:32 PM
Paradigm
11-09-2012 03:39 AM
