A stupid question about how to find non-OEM brake pads
I need new rear brake pads & rotors, but the OEM pads cost $250 each. I've gone to my mechanic & asked him to find cheaper ones, but he says those are the only pads available for the Jaguar 2004 XJ8.
I know this isn't the case, but I don't know how to find brake pads that fit my car. How do you go about finding non-Jaguar rotors for a Jaguar, and how do you know they'll fit?
I also need new rear links, and similarly don't know how to find non-OEM ones.
Try:
Akebono Online Parts Catalog
Select "Vanden plas", for some reason they don't have XJ8 as model, but the brakes are the same.
EBC has online catalog, but you have to sift through it:
EBC ecatalogues for Motorcycle & Automotive Brakes
Amazon has a good selection and search by vehicle model.
Go to the "How To", Section
https://www.jaguarforums.com/forum/x...service-61323/
Try Rock Auto, Jagbits or Autozone for sway bar links. Sway Bar Repair Kit | 2004 Jaguar VDP 8 Cylinders 4.2L SFI DOHC | AutoZone.com
JimC64 (02-01-2014)
However, one thing I NEVER buy from them is brake pads. Too many lower cost aftermarket sources available for OEM quality and better quality pads.
Links are usually on the ends of sway bars in this case
You will recognize them located on the ends of the sway bars were they attached to the sway bar and and another point on the moving suspension.
BrentGardner
28
04-26-2024 03:08 AM
