Suddenly, no more audio in my "new" XJ8!
First, many thanks to all who contributed with their worthy input on my "no audio" problem.
I finally caved and brought it in to the Jaguar dealer and I just learned that the cause was a bad power amplifier (BTW, that was my initial inkling). That's the good news. The bad news is that the part is $1100! As if that wasn't enough, they charge 2 hours of labor to install it. (What they don't know is that I removed it and replaced it once already and it took me about 20 minutes.)
Well, all this is just unpleasant because my 100K mile Select warranty expired 3 months ago and the car only has 34k.
Really love the cat, but no one ever said that love is easy...![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Not to mud up the thread, but metra makes the adapters you need...
This is Jaguar male to standard motorola:
Car Antenna Connector Adapts aftermarket radio to factory antenna connection - antenna adapter - vw antenna adapter 40-EU10 METRA
And then back
Adapts aftermarket antenna to factory radio 40-EU20 METRA
No hacking or cutting needed.
George
And then back
George
Thanks!
Received 9,010 Likes
Sounds similar to issues I'm experiencing too!
See my thread here, what I've done so far and where I'm at.....
https://www.jaguarforums.com/forum/x...tently-154827/
Thanks for excellent content here in this thread. I have lost all sound too. My car sits on a hill facing downwards so water sits in the critical area! I have used a black sealant from Halfords in the UK £5. Granville. Very easy to apply. My Jag is X350 XJ 2003. I am breaking my old 1997 XJ8. Do you think that the amp out of the boot / trunk would be compatible?
Again thanks for tips. (2003 XJ X350). I have now replaced the amp, which had suffered from water. Mine was labelled 2R83-18C808-AJ. It is an 'Alpine'. I believe that the final letter is irrelevant as are also fitted in some X types and S Types. So I widened my scope by searching for 2R83-18C808-A and ended up with a 2R83-18C808-AC which worked perfectly. Just hope that the sealant works well enough!
