Sun Screen inop
Has anyone had experience with rear window sunscreen on 05 VDP. There is a click when button is pushed but no action. Fuse good. It seems someone has cut an access hole in the trunk forward finish carpeting, maybe to give it a push? I'm sure I can survive without it but would be nice if everything worked. Thamks.
Also check the corners for binding.
After getting mine sorted I leave the rear sunscreen in the extended position and cycle it once monthly. That seems to do the trick.
My rear sun blind isn't working. I tried prying up on the ends of the sun blind while I had an assistant hit the button. I lifted the ends up about an inch on either side, but the center of the blind will not pull out of the recess. While I hold the ends up, when the button is pressed, the blind retracts rather than lifting up. I can probably yank it out of there if I pull hard enough, but I'm afraid I'm going to break it. Is this something like you all experienced when pulling out the blind?
If the blind motor is still working, you should hear it and feel it trying to move, when the button is pressed, if there is no movement or sound at all, then there will probably be a fault in either the fuse, switch, wiring, or motor. I don't know off hand which fuse operates the blind, but I would start from there.
The motor is working.
