Sunroof shade Interior trim removal.
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20190309_164026_bdfeefcb1f917ae7164b73b4c9f9a8d3750704c2.jpg)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20190309_164042_e8227ddcd65bd9d7bfc1e2e89446153f813a5e16.jpg)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20190309_164105_adaf98fc9e4fa00ccd770e20ae71109c3c1bae73.jpg)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20190309_164120_a77a04d5bda6fb765182003dbb38850a934571aa.jpg)
Still searching this topic, you do not have to remove the glass or the whole sunroof mounting bracket.
Once you remove the entire headliner, you will be left with the sunroof visor, if you open it a bit more than halfway you can see a stopper inside sticking up from each side or down depending on model.
but if you take a long screwdriver you can work the pegs past the stops.
then when its all the way back it will stop on the sunroof drain , it can be easily worked past this as well.
reverse to install.
Poet
10-06-2015 09:40 PM
1964Daimler
09-09-2015 11:28 AM
