Supercharger removal - what can I clean?
I removed the supercharger on my 04 XJR to replace the coolant hose. Everything is pretty dirty after 103,000 miles. What can I safely clean? I know you're not supposed to clean the throttle body, so I just wiped it with a rag. What about the intake elbow and supercharger outlet pipe? Anything wrong with dunking them in the parts washer? Yes, I know the inlet elbow has the MAP sensor, and yes, I already broke it getting the connector off. A new one is on the way.
How about the supercharger itself? Carb cleaner and a stiff brush on the lobes?
For the supercharger I disassembled it to rebuilt the bearings and change the pulley so only cleaned the lobes with a clean rag with a little machine oil on it and cleaned the inside of the body with some degreaser being careful not to get any in the needle bearings at the back of the case. The coating would probably come off with any kind of scrubbing/ solvent.
The intercoolers, thermostat housing, throttle body elbow and outlet duct all went into the parts washer @40C for an hour. I then painted all the parts up with Eastwood Aluma Blast.
Mine was all the same as yours, after 90 odd thousand miles it was all pretty black and oily wish I had some good pictures the throttle body elbow was the worst, just as an aside I did change all the gaskets and seals before putting it back together, the dis-assembly isn't something I want to repeat in a hurry...
Don B (11-30-2015)
Starting to put the car back together, but I discovered the EGR pipe is cracked at the flange so I'm waiting on a new one. I got everything cleaned up, but the parts that I think will really make a difference are the intercoolers. They were extremely gunked-up. I left them in the parts washer for a few days, and flushed them with water several times. Then I used about two cans of throttle body cleaner on each one before they started flushing fairly clean. I'm sure they were pretty restrictive, flow wise, and probably not doing much cooling either.
Is it possible to take them off without removing the whole supercharger?
Bruce Caulley
45
02-22-2017 10:37 PM
SharpJag3
11-17-2015 04:27 PM
SharpJag3
11-15-2015 04:59 PM
