Supercharger removed, what did I get myself into!
Well, after a few frustrating hours I got the supercharger removed. Attached a pic for proof. The hardest part is getting to everything on the back side of the SC. The EGR is a major PITA. In case you're wondering, I had to remove the SC so I can rebuild the snout. It was making a rattling noise at idle. I opened the snout up this morning and found that the spring loaded coupler was broken. So now its a matter of rebuilding the snout with the kit I bought. I splurged a little and got the low friction ceramic bearings and performance seals.
But now the real headache is about to begin. I'm going to have to put it all back together. I made the mistake of rushing through the removal of everything and not keeping track of hose locations. Does anybody have a pictures or diagrams showing the routing of the coolant hoses to the EGR and the throttle body?
I also need to order some of the vacuum hoses and coolant hoses that go to the EGR and throttle body because the hoses were hard as a rock and broke during the removal. I can't seem to find any parts listing for the throttle body hoses on the dealer websites.
Any help you could provided on the installation of the supercharger would be great. I already have the SC R&R guide but its a little lacking on the details.
chemosabe (07-10-2022)
Muddybear (11-05-2013)
It changed in construction at some point and at least the earlier form tends to leak after a while. I don't know if the later version also does but I'd swap the hose for a newer one while in there.
The tech Brutal says to slot one of the mountings (I think it's the rear one) for easier reinstall if you hunt through the thread.
So an update, I borrow my friends press and rebuilt my supercharger snout. Only took about 30min to press in the new bearings. I went with the low friction ceramic ball bearing kit. I got the kit from Rolling Performance Home.
And now I just finished repairing my intake elbow. Here's a link to the thread I made on how I did the repair. https://www.jaguarforums.com/forum/x...ng-fix-105997/.
Now on to the next project.
Still waiting for some coolant hose before I can attempt to put everything back together, so I had some spare time to further polish my intake. This time I used an actual polishing wheel with some metal polish. Came out really nice using the correct tool. Hopefully my parts show up this week and I can start putting it all back together this weekend.
Panthro (03-31-2016)
aholbro1
08-05-2021 05:02 AM
