susp. pump experiences
Took the pump out of 04 XJ project. Lots of surface corrosion, frozen cylinder bolt, water inside air dryer, retaining spring dissolving. Cylinder has a very slight Ridge, hand reamed to break glazing to little effect. Motor, crank, seal all looked good. I think the desiccant was causing a lack of air. Ordered off eBay a used pump from California. Arrived today, it looks great, no corrosion, disassembly markings visible many places, I'm wondering even if I should open it up. My opinion is that pump is a good design that should have been made more accessible, particularly the desiccant. The motor/crank seems quite strong. The cylinder and all wearable parts should be made available. Are they?
