Suspension/brake question
At low speeds when I tap the brakes there is a clunk. At first, I thought that this was a some feature of Jag brakes that apply the rear brakes first as an anti-dive feature. Now I am not so sure. The main suspension culprits seem to be sway bar links and bushings? Is that where I should look first? The rubber boots on the upper control arm have rotted away. Incredible! The car has only 54k miles.
Take to alignment shop
I had to replace ALL the arms and links in my 2006 in 2015.
Also check the rear toe adjusters.
A good alignment shop can find all the worn parts by movement.
I think Ford spec the wrong rubber on all these parts. They disintegrate to fast. These are Lemforder and only the Jag, Ford, and Lincoln parts they build do this. They are all the same. I used Ford dealers for most parts and Rock Auto for the rest.
Dan R (05-04-2018)
texevora
10-31-2015 08:43 AM
MANIACK
05-30-2012 09:06 AM
catniped
04-19-2012 11:13 AM
jaguarNeWb
12-01-2010 09:42 PM
rx8rotary
08-19-2010 08:13 PM
