Suspension bushings
Suspension bushings
I'm wondering specifically which suspension bushings usually wear out at about 100,000 miles on a 2007 XJ Super V8? I plan to have my front and rear air suspension replaced and I was thinking have the bushings susceptible to wear and tear be replaced also. I wanted to know this info before I take it to the indie shop so I can buy the bushings at a Jaguar dealer parts dept.
Not that easy.
The uppers are tough, the bushings seem to hold up okay, the ball joint boots sometimes fall apart. Same with front and rear tie rod ends.
The rear lower bushings are really bad about failing.
Don B (08-12-2015)
