suspension is done!
suspension is done!
after researching the options, i decided to go the route of using s-type suspension components to replace all the air shocks on my 2004 xjr-
While I was at it, i replaced the sway bar links, and all bushings i could find a replacement of.
I got H&R springs from tirerack.com. These are s-type lowering springs. I got bilstein shocks from auto anything since tire rack was out of them. These are for an s-type with sport suspension. No CATS..
All in all it wasn't a bad install. The toughest part was finding the bottom spring seats. I ended up buying old use whole s-type shocks/struts off ebay just to get them. Since the bolt pattern does not match up for the top of the strut i had to "adjust" the holes a little to get them to fit.
The car is a whole lot lower. I'm happy with it and the new improved handling.
Panthro (07-21-2018)
That was the first thing on my list to be done along with new tires
Local jag dealer tried but couldn't because it was too low to go up the ramp. I had to get a tire chain shop to do it.
Wow.. looks perfect not too low. I personally don't like fender well gaps.
from auto anything
Bilstein Touring Class Shocks Front
SKU 3764865
Part # 24-067430
Vehicle 2005 Jaguar S-Type
Submodel 4.2L V8, non-supercharged, with sport suspension, without CATS
2 $125.99 Ships between 07/09/2013 - 07/11/2013
FEDEX Home Delivery $251.98
Bilstein Touring Class Shocks Rear
SKU 3764991
Part # 24-067720
2 $107.99 Ships between 07/09/2013 - 07/11/2013
FEDEX Home Delivery $215.98
from tire rack
H&R Sport Spring Set (Premium, Performance Street)
Front and Rear Fitment
Ride Height: Moderate Lowering
Note: Avg low 1.3"F 1.2"R
Performance aftermarket shocks or struts is highly recommende d in this application. Price: $310.00 (kit)
Estimated Availability: Fewer than 3, Special Order Available
Manufacturer Part #: 29436
from rock auto
MONROE 904972 Strut Mount $ 29.79 $ 0.00 4 $ 119.16
I got all my bushings from rock auto as well and the strut mounts were a little cheaper. It wouldn't make much sense to make an order from rock auto just for the strut mounts since tire rack has them also
As i mentioned before, I could not find a source for the lower spring seat. I bought old used s-type spring/struts off ebay just to get the bottome spring seat. If you go this route, it would be possible to use the bottom sprint seat and the top strut mount from the "donor" parts.
I got a local tire/suspension shop to pull the old struts apart and re-assemble with the new parts since it was a lot faster than me using my spring compressor to put the struts together.
I used an air die grinder to adjust the bolt holes
Thanks!
It sure could. I got the idea from reading this thread where SexyBeast swapped in stock s-type struts. So, stock s-type springs would work as well which should put it a little over an inch higher than mine.
dmatthewman
09-30-2015 10:10 AM
