Suspension noise
Hi Guys,
I have a suspension related question for you. Some month ago I replaced my struts to new bilstein ones, and also replaced the compressor. So, the car stays on level for even a week, and it rises and lowers like a charm. No problem with the damping as I feel . But since it's getting cold outside, I started to hear koncking noises from te suspension, and i feel it on the steering wheel also, I feel something "loose" (however, damping remains to be good, no problem passing a bump). It feels like very old and worn damper on a normal suspension, but my Shocks are brand new, and the car just have it's license renewed, where the shocks were measured and found to be perfect.
This behaviour stays for about 10-20 minutes, and then slowly disappears, completely. It looks something is getting warmer, and works normally after.
I was suspecting the little stabilization bar on the front, or the busing where the shock is attached to, but can it get better after half an hour of driving? I don't think so, but I have no experince about this, anyone had the same issue?
Regards:
Barna
Regards:
Barna
Hi Guys,
Regards:
Barna
Regards:
Barna
Try removing the sway bar link from one side and see if you still have the noise.
My bushings had about 1mm play when I removed one sway link on one side and tried moving the sway bar.
Hooshee (01-20-2016)
That sounds like what i had and finally changing the sway bar bushings fixed it. The noise was most noticeable when cold and lower speed when one wheel went over a bump.
Thanks you!!!
JimC64
10-13-2015 07:08 PM
