suspension noise
hello everybody
as i have a noise on humps , i started to investigate the car , which i have only from few days .
i knew suspension has some work to do before buying it.
i took picture of upper arm left front , which is here
![suspension noise-photo-2-.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/43702d1480968548t-suspension-noise-photo-2-.jpg)
can someone tell me if this is normal condition for such part or not ( honestly i think not ) could this be the cause of the noise ?
thanks for your comments
rgds
thierry
Dubai
rgds
thierry
Dubai
A split ball joint boot like this means the ball joint is likely to be shot. You have to replace the whole thing, as the ball joints are not separately supplied,
Jaguar S-Type, X150, X350, X351 (new XJ), XF Wishbone Upper Rear RH (C2P13876-O) | JustJagsUK.com=
Other places to check are : -
Lower wishbone bushes
Spring/shock unit lower bushes
driver safz
09-26-2015 06:01 AM
