Suspension question
Well... more. I paid a little over 1200 US$ for my set last year.
Couldn't be happier, though. The air system was pretty much a complete loss, with lots of water in the system, so lots of corrosion.
I've only seen two companies that make the CATS bypass module to go with their shocks, Arnott and I think Strutmasters, but I'm not sure Strutmasters covers all the XJ models.
you don’t need a bypass module if you have an x350 (pre-06). let us know how it sits, i put a set of s-type struts on and the fitment and ride is impeccable.
https://m.aliexpress.com/item/400106...640x640Q90.jpg
Changed air filter pollen filter, then for my reward a coil failed so fitted a new one. The left bank looking from under the bonnet breather pipe was looking in bad condition and moving about collapsing so I cut the middle six inches out and put some copper pipe with jubilee clips on it, it will not collapse again, only to be again greeted with restricted performance but deleted that and it seems to be ok again, I’ve only had it a week but I’m at war with it I will make it perfect👍
