Systems Failure brake fault...etc ,, Please help
Hello Folks
I have a 2004 VDP that recently developed few codes. Most important is P1229 and P1338 but the P1338 didn't re appear when I erased the codes using a scanner. When I start the vehicle it shows systems fault, parking brake fault...etc and when I press the gas pedal rpms doesn't go beyond 1200-1400 rpms.
Does this mean I am gonna need a new throttle body? please help me out![Icon Rant](https://www.jaguarforums.com/forum/images/smilies/icon_rant.gif)
As said Veffremov.
New TB. After one year of experiments with my S-type, I bought new TB and I am w/o problems for three years.
New in UK (NA, from VIN (G49701)) :
Jaguar Partno_AJ811770_BODY-THROTTL_David Manners Group Discount
New in UK (SC, from VIN (G49701) To VIN (H24092)) :
Jaguar Partno_C2C24624_BODY-THROTTL_David Manners Group Discount
Maybe will be helpful.
Very unlikely to be the throttle body IMO.
VERY likely to be the just TPS which are available now.
To replace I would photograph the positions of the two screws holding
the TPS in place and set the new TPS in the same position.
The TPS is supposed to be fitted to a set voltage but I think the above procedure would be good
enough.
No harm in cleaning the TB at the same time of course.
enough.
genec (03-20-2017)
Yes it is TPS, if you want to try and replace only that part. New TB comes with new TPS, so it solves the issue as well.
Here is a link to the TPS part number. The TPS position would likely needs to be calibrated.
https://www.jaguarforums.com/forum/x...4/#post1037030
Here is a link to a more affordable throttle body for NA engines:
Jaguar S-Type - X200, X350 Throttle Body - V8 (C2C20540) - JustJagsUK.com
enough.
enough.
FYI, along with the normal weird electrical gremlins associated with this bizzar problem, my windshield wipers are moving a bit on their own, sometimes they crawl half-way up the windshield! But the car still runs fine. No limp-home mode.
BTW, this whole issue is a real head-scratcher. I've never seen so many "fixes" for a single problem. Everything from a new battery, to cleaning the TB to replacing the TPS to a damaged wiring harness/connector to something in the fuse block. Very strange.
Thanks again for everyones help.
