Tail Light Chrome Surround not flush anymore
Anyone seen this and know of a solution? On the d/s rear tail light, the chrome surround is no longer flush with the plexiglass of the light. It has a gap of 3/4" on the outside. The inside stil lappears to be attached to the light. IMHO this design looks like junk, on every XJ8 I have seen, this piece of trim flaps around.
Is the solution a replacement of this part (I suspect TX heat may have something to do with it)?
- Tim
- Tim
Received 2,192 Likes
theres a bulletin on fixing and applying special structural trim adhesive to resecure the trim...the repair method and adhesive sucks and is yellow, if not super carefull it will show since it tends to expand alittle when curing.
I prefer to carefully clean the rubber attached to the trim and clean the light. Then carefully pull away from the light and run a thin bead of Super Glue to the contact surfaces, press, hold, release. Note:if youre sloppy, the release might be a problem.
Youre done, and it works great. I have never had 1 come back off Ive done
Nish (06-05-2023)
I had the same issue and paid to have it corrected. The dealership then attempted to fix it with "glue" and it was horrible. They left finger prints all over the lens/trim and there was still an unacceptable space.
They then replaced them both under the extended warranty by telling Jaguar Canada that the rear tail lights had failed. At $400 / unit, it would have been an expensive repair on my end and, IMO, should not be an issue on this vehicle.
Corrected in later years.
Just a quick update, as part of a lot of work yesterday, the dealer fixed the rear surround for free. They used a 2-part black epoxy glue and did a very good job, they removed both lights to work on them. You really can't tell that any work was done, the glue bead is very even and now the surround is not flapping around!
All I need to do now is work out why one of my Xenons is flickering....
- Tim
- Tim
Tim, my right side xenon started flickering about three months ago. It finally blinked out. It was repaired last week by our friend Brutal at Momentum Jaguar here in Houston. The work order shows that the bulb and burner (C2N1716) were both replaced. Since the car is still under Select Edition, I don't have a detail of the actual costs. I spoke with Brutal by phone and he said the parts cost would have been a little over $400. I hope this is helpful.
