Temperature Gauge Stuck on Cold and Red Light On
After about 5 miles of driving my '06 Super V8 this afternoon, I noticed the red light on at the top of the temperature gauge but the needle on the gauge was at the bottom as if the ignition was off or the gauge wasn't connected.
The electric fan was running until I shut the engine off. I didn't remove the reservoir cap but the engine seemed to be at normal temperature. Nothing was displayed on the message centre.
My guess would be a faulty temperature sending unit has tripped the red light. I didn't find anything in the owners manual about the light and wasn't able to find an account of a similar situation here.
Anyone else experience anything like this?
Updated: After letting it sit for about 30 mins I removed the cap and there is plenty of coolant in the tank. If it's low it would be by about a cup.
thegreenjaguar (02-01-2019)
Thanks for the replies . I only mentioned the owners manual because I couldn't find anything about the red light on the temp gauge there. It only mentions the needle on the gauge. I hadn't even noticed there was a light until it came on.
I'll run a scan but wouldn't be surprised if this sorts itself out, at least temporarily.
Here's when I posted this happening to me (with photo) https://www.jaguarforums.com/forum/x...failed-165656/ You're correct, the owner's manual says nothing about the indicator.
overheating
Hi
I bought a great little OBD device that makes my life great - going to drill a hole in my ashtray to install permanently. Should be under $36, such as
[url=https://www.amazon.com/AUTOOL-Multi-Function-Water-Temp-Malfunction-Test-Automotive/dp/B07L8RPLCG/ref=asc_df_B07L8RPLCG/?tag=hyprod-20&linkCode=df0&hvadid=312280085431&hvpos=1o4&hvne tw=g&hvrand=15670769638953492171&hvpone=&hvptwo=&h vqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1013509 &hvtargid=pla-632688059030&psc=1]
I now take it from car to car as they all seem to have idiot light-fake gauges.
really helped me make sure I purged all my air after my last coolant flush
namlops
09-02-2023 01:17 AM
john_cook12
03-02-2020 01:03 AM
Sober Driver
09-21-2018 09:58 AM
Zulu4me
10-03-2017 06:55 AM
Chuck Schexnayder
08-26-2017 02:40 AM
