That's the way the Radiator crumbles...
The upper radiator hose popped off and started dumping coolant (fortunately on the driveway and not the highway). Once it cooled down a bit, I was surprised to see that the connection point for the upper hose had split into pieces. Time and temperature obviously took a toll on the plastic portion of the radiator.
This brings up two items -- one, if your beast has the original radiator I would recommend proactively replacing it before it gives up the ghost at the wrong place or time.
Second, since I'm going to have to tear into the beast to replace the radiator, what other things should I source and replace while I'm in there?
Thanks for you help!
Patterson (05-31-2022)
In replacing the radiator, you may want to insure the foam that lines the sides of it is in tact.
These foam bars block hot air in the engine compartment from escaping forward and flowing in front of the radiator, and back thru it.
Better to draw cooler outdoor air across the radiator and AC condenser than heated engine air.
Patterson (06-09-2022)
