Is there a specific X350/X358 DTC PDF to download?
I was wondering if there is a specific PDF that has every single DTC listed available for download and searching?
If not, is there a way to make one from JTIS or the Manual PDF's?
I currently have the time and inclination to make one if there is not one already?
That would be a handy reference to have. I usually check OBD-Codes OBD-II Trouble Codes - DTC Codes Car Repair which is helpful on the general codes, but is not Jaguar specific.
Here's a different link to the same 153-page version of the 2004 DTC manual that Sean linked to. There is also a 74-page version containing only the Powertrain DTCs but this is the most helpful version I've found. The advantage of this document over more generic ones is that it provides the Monitoring Conditions, Default Action, Control Module connector pins, and Possible Causes for each code, specific to the X350, all of which can come in handy when trying to diagnose the root cause of the code:
https://www.google.com/url?sa=t&rct=...03388427,d.cWw
There have been a few codes reported by forum members that do not appear in the DTC Manual, but may appear either in the relevant section of the Workshop Manual or one or more Jaguar TSBs. The next time one of these turns up I'm going to check Cambo's Ford list, which certainly appears exhaustive.
Cheers,
Don
Cheers,
Don
There's a newer one that's 152 pages.
That AJ3X_AJ6X_AJ8X_EMS_OBDII_2005MY.pdf document is interesting because it is organized by EMS monitoring circuits/sensors, but the actual lists of DTCs are very abbreviated and there are no B or U codes at all.
I couldn't find the "newer one that's 152 pages." Do you know the file name?
Thanks,
Don
AD2014 (11-13-2015)
i_am_trosty @ hotmail . c o m
Now that's going to be difficult to put on the web site if it is larger than the upload limit.
Unless an Uber admin can put it on the website using his super uber powers with no upload limitations possibly?
Or a smaller sectioned version for us lesser mortals to be able to upload to be added to the links page?
NormB
11-03-2015 11:02 AM
