Is there a trick to tremoving the red rear side running lights
RE: Is there a trick to tremoving the red rear side running lights
This is a rather tricky maneuver. You need some time of tool which will give you leverage to push it up far enough to swing the light out from the bottom. They can become somewhat seated in place if they have not be recently removed. The plastice tool is a good choice to keep from breaking the lens as long as it is sturdy enough to take the pressure without breaking itself!
BrentGardner
28
04-26-2024 03:08 AM
hafren
08-30-2023 03:42 PM
