are these auto trans the same?
Old 05-18-2021 | 08:09 AM
the brain's Avatar
Default are these auto trans the same?
Hello
Would an automatic box from 2002 xj8 3.2 be the same as 2004 xj8 3.6
I want to swap the older one into my 2004 as trans is playing up
thanks
Old 05-18-2021 | 10:02 AM
wfooshee's Avatar
They're different transmissions. The 2002 is a 5-speed, the 2004 is a 6-speed. Controller electronics will be completely different.
Don B (05-26-2021)
Old 05-26-2021 | 09:47 PM
Don B's Avatar
I have had good success restoring the 6-speed ZF transmissions to proper operation by changing the pan/filter and connector sleeve, flushing the fluid, then using SDD to clear the adaptations and update the firmware to the latest version (2006).
Short of that, you should at the very least inspect for fluid leaks at the pan gasket, because low fluid will cause slipping. Also inspect for fluid in the electrical connector, which can cause various other malfunctions.
Cheers,
Don
The following 3 users liked this post by Don B:
motorcarman (05-26-2021), the brain (05-27-2021), Tigre (05-27-2021)
MRomanik
Non-Jaguar Vehicles
03-28-2015 01:18 AM
2jag
01-22-2013 12:21 PM
belsy
05-28-2011 02:48 PM
XJ ate
10-04-2009 03:22 PM
jensenguy
08-14-2009 01:43 PM
Quick Reply: are these auto trans the same?
