Are these the characteristics of the X350 XJ8?
Guest
Posts: n/a
Ever since I bought my X350 XJ8 about two months ago (its a mid-04 3.5 litre long wheel base with 60k miles), I've been plagued with a series of "unpleasant experiences" and the car and had been in and out of the authorised service agent (as its still under the 3-year warranty period) for the best of three times. I had complained of vibrations from the steering, an "ooking" noise from the rear of the car when accelerating and the brake pedal juddering occasionally with the ABS/DSC lights and message appearing (on 3 occasions when braking on dry roads in perfect weather condition). I had also complained about the aircon compressor making a "rather audible roaring noise" when the aircon is shut off prior to shutting down the engine.
I have suggested several possible causes of these problems, ranging from a bentpropellar shaft, worn bushes to a failure of the ABS module. However, a senior tech (who claimed he had been working in the service dealership for the last 13 years and driven many manyy XJs) told me that some of these "complaints" are but just the characteristics of theJaguar, especially the XJ8 X350. I told him that I had owned 2 other Jaguars in the past (a XK convertible and a S Type) but yet none of them displayed the problems which I was facing with my XJ8. The senior tech then told me the following:
a. the X350 XJ8 has an alluminium body and air suspension plus CATS. Hence, due to the construction of the car, my feel of the car would be different from the other 2 Jaguars I had owned, which were largely made from steel. Due to the design and construction of X350, I would be able to "feel" the road better (or for worse) because the air suspension plus CATS was meant to make the X350 "feel more sporty." In a way I do agree with him about the sporty nature of the drive (not unlike some of the Porsches which I had previously owned), but I refused to accept that "feeling every bump and undulation" of the road was meant to give me a sporty drive. I see the X350 as a "luxury car" which should provide me a comfortable ride, without feeling every inch of the road. I had also changed all 4 tyres in an effort to achieve the comfort.So is this really how the X350 drives? I would appreciateif any of you guys could share your driving experience on the X350 with me, comparing to other cars you've driven. My last car was a BMW 530i (E60) and I never had this sort of feeling from the bimmer.
b. the tech also told me that the X350 steering does not have "damper system" unlike in other continental cars like the BMW or Merc. He added that Jaguar had tried to install a steering damping system in a previous range(he didn't say which model) but the system caused so much problems that the designers and engineers decided to remove it. As such, the "very direct feel" of the X350 steering was caused by the absence of a steering dampling system. So my question is, is this true? Or is the tech just trying to avoid making the repairs since the car is still under warranty?
c. I've read in this (and other jaguar forums) about the ABS/DSC lights coming on for no obvious reasons. Is this a "weak point" in the X350. The tech told me that during my last visit, they plugged in the computer and the diagnosis did not show that there was an ABS/DSC failure. However, since he had witnessed the lights coming on, they had decided to clean the ABS/DSC sensor contact points as they might have become dirty and provide convulated readings. I took his word but a day after collecting my car, the ABS/DCS lights came on again after less than 5 minutes of travel. I had to brake, the pedal juddered and the lights came on. But after I stop the car,turned off the engine and turned it on again, the lights (and message) disappeared. This has become a quirky characteristic of my X350.
d. As for the "ooking" noise, the tech told me they had added some oil additive to the gear and this should cure the problem. Something like a "cough mixture" for the gear box I presume. But so far, this appears to work as I "hardly hear" the noise when accelerating from a high to low gear.
e. as for "roar" for the compressor (and not the V8 engine !), the tech suspected that it could be an aircon compressor problem and had agreed to change a new compressor for me. I'm waiting for the replacement part of come in from the UK. So I will update when the repairs are done.
All said, the questions now remain are:
a. "am I too sensitive" to how the X350 feels and drives, hence the reasons for meexperiencing such unpleasantness with the car? I have owned almost 40 cars in my driving career which spans almost 30 years and driven many more others. However, I must say that my experience withthe X350 is "really one of a kind" compared to the many Japanese, German, Italian, French, Swedishcars and the 2 other Jaguars that I had previously owned. Could it really be that because the X350 has an alluminium body that it drives like that? My BMW 530 has an almost all alluminium under carriage, but I never had such a feeling when driving it.
b. are these really the characteristics of the X350? The tech told me that "new owners" of the X350 had similar complaints because they were "not orientated" to how the X350 actually feels. But previous owners of XJs (X300 and X308) seem to love the X350 because its lighter and more "dynamic."
I really need some assurance from other X350 owners about my car, otherwise it would not be long before I dump my XJ8 and find a replacement. And from this experience, it wouldunlikely be another Jaguar and it would be a long time before I consider this marque again! So help is really needed here for me to keep my trust in this brand. Thank You.[:@]
I have a 12/2004 XJ8 and I have not experienced any of the things you describe. I aslo work at a BMW dealership and have driver many a BMW and the ride in my XJ8 is as good as any BMW IMHO. The only thing that I share with you is a problem with the air suspension compressor ( I was
having a general air suspension fault), it was replaced and I've had no issues since. I will also state for the record the following:
a) I live in N. California and we have some of the most F'ed up roads in the CONUS
b) I drive my car HARD!
I'm also curious if you turn off the DCS do you still get the lights ?
a 350 should drive nice and smooth.. like "on a cloud" kinda of feeling.. anything less they have no idea what they are doing.. i wud take it to a dealer where they know what there doing.. steering wheel .. shud be nice and smooth as well.
And you shoudn't feel and road feel.. whatsoever. Depending of the condition of the tires..
It does drive different then older jags such as x300 and x308.. it drives better and smoother
I have the XJ aluminum bodied car presently. I previously drove a 1997 XJ. I believe the new car to ride and handle in a superior way to the older car in my subjective opinion. I concur with the above comments that the car should ride silky smooth with a sport feel in terms of road contact/holding. Get a qualified second opinion from a trusted source with Jag. experience. Don't give up or settle for less than par performance from this car.
And, in defense of the dealer, I don't think they are trying to avoid fixing the car. It does sound as though they are writing you off with lip service.
a. The ride should be smooth. No question about that.
b. Steering shoud be smooth as silk.
c. Sounds like comprosser and that they are willing to take care of this for you. Don't forget the drier!
d. I believe the cough surup thing. Great description and it really does work.
air, codes, comments, complaints, compressor, fault, forum, forums, jaguar, suspension, tires, trouble, x350, xj6, xj8
