Throttle Body Replacement
Good evening to all. I have a 2005 XJ8 that I'm getting a P2135 code on. It appears that the TPS is part of the throttle body and the entire unit has to be replaced.
My question is this. If I replace the throttle body myself, does the ECM need to be programmed for the new part or will it simply work with the new throttle body?
Your insights are appreciated.
I moved your post out of the regional section.
The TPS is not available to buy as a spare part from Jaguar, so they will tell you to buy a complete throttle body.
However the TPS is the exact same item used on other models too;
2.5L and 3.0L X-Type (all years)
2.5L and 3.0L S-Type
4.2L and 4.2L S/C S-Type (up to 2006)
3.5L, 4.2L and 4.2L S/C X350 XJ (up to 2006)
The part number for the TPS is Denso 198500-3300, do a search for this part number.
Aftermarket TPS do turn up for sale on eBay every now and then.
Or you can find the cheapest "new" throttle body from a V6 and take the sensor.
RLB828 (10-24-2015)
Thanks Cambo. I found the TPS party number that you gave me and was able to get one on EBay for $50. I swapped it out and the car is running great again.
I figured it was worth a $50 gamble to try a used part and save $325 on a new throttle body. Very grateful to you for your help.
And yes, the VIN is lower that G49700.
Don't re-use the gaskets! They are a one-shot only item.
I didnt reuse any gaskets. I ran into another another thread that suggested doing a drain and fill on the Trans. Something about the hard shifts from the 'system failures'. It sounded stupid but I have not changed the fluid, so I figured I would give it a shot.... It worked. The car is running better than ever. I used Lucas universal synthetic Trans fluid.
@cjd where was this information a long time ago? ha! does that work when you do a tps replacement too?
To anyone else... I would recommend not doing the TPS replacement unless your tight on cash and need it RIGHT NOW. Just do the whole throttle body. If the TPS went out, its just a matter of time before the throttle motor starts acting up too. You can pick up a new TB from some of the online retailers now for about $250 shipped. If I wasn't such a cheap a$$ I would have done that in the first place and would have saved myself time and money.
only1gina
44
12-10-2015 01:46 AM
