Throttle Body Replacement, we are getting hosed
#43
Surely if someone replaces something like a TPS it's their problem.
I'd very much like to look further into a TPS sensor replacement since they cost <$100 rather than >$2000 and, as has beed mentioned, failure can be the death knell for one of our cars.
It would be interesting to know how often the throttle body motor fails - that would be a different story.
#44
but why does everyone else sell the TPS alone.
Anybody had any trouble with a rebushed wishbone, (or know of anybody) ?
#45
I am having this same issue. I refuse to replace a throttle body that is fine, just for a "bad" sensor. This is an engineering mistake. Its dangerous as hell. Mine malfunction seven times today with my kids in the car, no shoulder to pull onto and on an extremely busy highway. Jag needs to figure this out. Love the car, hate the bs. Now, has anyone replaced just the tps on these x350's yet?
#46
I've looked at a DIY replacement for the TPS and, surprise, surprise, it isn't as easy as you'd think.
https://www.jaguarforums.com/forum/x...acement-77560/
I wonder why !
I wonder why !
#47
#48
If I remember the reason for the recall had nothing to do with the TPS. The early cars were jut reflashed to add the cleaning sweep & the later ars which were not programable had a new throttle body fitted. The issue with throttle bodies actually failing was not at all common in the 90's. I do also agree it would be very nice to be able to replace the TPS.
#49
Would it be worth my time to remove the sensor and clean it with some alcohol?
#50
If you're prepared to risk writing it off you can get it apart by grinding off the lip of plastic holding the metal back plate on.
You can then clean the tracks and wiper with electrical contact cleaner, tape the back on with sellotape and replace it to see if you've fixed it or ruined it.
I polished the tracks on the dead one GGG (Graham) sent me with chrome cleaner and it appears to work correctly now.
If fixed then araldite the back plate in place.
Don't blame me if you wreck it though, nor if it packs in on a railway crossing with a train bearing down on you.
#52
#54
#55
ASI - 1999 2003 Jaguar XK8 XJ8 Stype Throttle Body TPS Rebuild Repair
us dollars 485.00
I found this on the net they offer a life time warranty? on their rebuild and the price seems fair. But if they rebuild these things and the tps is included they must have a source. I wonder if they would sell just the tps? I am knocking on wood so I can ward off the murphy omen.
us dollars 485.00
#56
#57
Please don't resurrect old threads, just start a new one.
Yes the TB for XJR and XJ8 are different. The problem is usually the TPS and it can not be "cleaned". Technically it can be replaced, but JAG does not sell the TPS separately.
You can get the TB refurbished, which is a lot cheaper than a new one. Also look for good prices on the Internet, I found new TB for XJ8 for less than $250.
#60
The thread is reasonable technical and it would be difficult to compile all that has gone on in another thread.
BTW, found a aftermarket TPS for a Ferrari yesterday ... $56 retail. So it can't be the size of the market.
