Throttle pedal dead zone
I recently bought a 2006 XJR as a weekend toy; I also have a 2003 XJ6 as my daily commuter car and I've noticed that compared to the XJ6 the XJR has quite a large dead zone on the throttle pedal, so it takes a reasonable amount of pressure/travel before it responds. It's not the end of the world, but it is annoying.
Any ideas?
Any ideas?
Any ideas?
Thanks![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Any ideas?
Any ideas?
Any ideas?
Process after battery disconnect is, throttle re-cal, audio code if required, set clock, park-brake re-cal, windows/sunroof anti-trap, windows one-touch. Then a drive for ECM adaptions.
Most aren't aware of the required re-calibration of the throttle pedal after battery disconnect.
mine seems to have a dead spot then a surge of power just after it , always has ! i just thought it was the second fuel pump kicking in . as it seems to be at around 4k rpm as well .
Datsports (08-16-2016)
is this the same with s type r ? it gives instructions on the message center to reset park brake but not any thing else .
FS[Western US]: XJ6 XJS Wheel Bearing Kits, Front, NEW, Never Used - $40
XJsc-guy
04-12-2016 02:09 PM
