Ticking noise under the bonnet when idling
does it increase if you rev the engine a little? I'd guess a bit of a noisy lifter. They are self adjusting so if they get a little crud in there they may not come up to full oil pressure and they tend to tap a bit.
Not a concern if so, but you can run some engine cleaner thru it right before your next oil change, often cleans it out. a can of Sea Foam is what I've used.
Wolfy (08-03-2016)
rosskuhns (08-04-2016)
i was reading one thread about this where the symptoms were pointing to the purge valve. I just replaced the PCV valve , and have a new purge vale. cant seem to locate this. can somebody please point me in the direction? my tapping sound does not sound engine related , but as one of the members said , can hear it in the lower left dash when idling. its PM# IJG151BB
thanks
thanks
Steve W
08-16-2016 06:03 PM
