Torque Converter Died - extra jobs?
So I assume its not allowing the car to move or is there another issue? Was there any indication prior that it was going out? The reason I ask the question is that i here a dull hum/ vibration when my car is in gear and at a stop. I suspect its my torque converter or something in the transmission. I thought it could also be collapsed motor mounts but they do not appear bad. The car has 130 miles on it. How many on yours?
Thank you
Wooford XJR
Thank you
Wooford XJR
I didn't experience anything like that. It was more a difference when driving. Very hard to explain, but it felt almost like a speed limiter was engaged. Or like the shifts were delayed. After driving a car for a while you of course come to anticipate the shifts, and they were coming a bit late. And I'm honestly not sure I was getting into all of the higher gears when highway driving.
AND - i was getting P0741!
- There is no transmission leaks.The transmission fluid level is at proper level at proper temperature
- There is no transmission fluid within mechatronic's sleeve. All pins are intact, nothing brocken
Just those basic things before diving into transmission swap.
Although the transmission does need to come out, it's not a transmission SWAP, correct?
I actually suspect maybe the converter was damaged by driving the car with a wrong MAF sensor? Or at least some undue stress was put on it.
@Wooford XJR - I'm at ~122k.
phd12volt
03-18-2009 09:06 PM
