TORQUE Spec.
At the attachment point at the wheel side;
Install a new nut and bolt. Install the front lower arm.
Stage 1: Tighten to 60 Nm. (45 Ft. Lbs.)
Stage 2: Tighten 135º. (1/3 turn)
At the body;
The final tightening of the front lower arm inner retaining nut and bolt must be carried out with the vehicle on its wheels. Failure to follow this instruction may result in damage to the component.
Tighten to 175 Nm. (130 Ft. Lbs.)
At the body;
The warning was copied directly from the Workshop manual. It is your vehicle and you can do whatever you wish, however, I would never final torque without the weight of the vehicle on the suspension. Good luck in your servicing.
