touch screen control...mirroring de
Wi-Fi & screen Mirroring from the phone (permitting your phone actually has screen Mirroring or Airplay)
Tks
So i put the touch membrane over my screen... but the screen is still working with touch ?
Where did you buy it ?
Can you give me mire informations about your new system ?
Tks
Tks
To get touch control you will need to install a touch membrane over the screen and have that connected to your interface
Initially I used an interface that did this but latter removed it for and android nav replacement. The touch membrane now controls the android box
34by151
34by151
Most systems use either a resistive or capacitive membrane over the screen to define the touch signal. These membranes have a ribbon cable with and X and Y output
Our system is different. It uses a matrix of IR led's that is built into the facia. These shoot an IR beam in the X and Y direction. A Touch input is defined when a beam is broken. This will happen in both X and Y and define the location.
When you have a membrane you are pushing on the membrane. With our system you are pushing on the screen itself.
If you fit a membrane over the screen you will not interfere with the IR Led signal but you need to add an interface to feed this signal to your mirror box.
The easiest way is a touch to usb interface but your mirror box would need a usb input
You could also interface with the phone via software or finally get a mirror unit that will accept a touch input
Take a look at this. I had this before my Android unit
MimicsX2 - Your Smartphone as your ultimate car stereo
or here for touch membranes
Touch Screen Control Panels for Car Monitors
Here for Touch controllers
Touch Screen Controllers for Car Monitors
Here for Android replacement units (switch between OEM anv and Android)
Car Navigation Systems and Boxes on Android and WindowsCE
Here is the thread on my install
https://www.jaguarforums.com/forum/a...hscreen-79908/
34by151
34by151
Hello
Is it easy to place the touch membrane on the screen ?
Sure it will not run the touch screen ?
Tks for help
Tks for help
34by151
34by151
The membrane is for your extra unit only. All the OEM functions still run from the oem touch control.
The OEM control is a matrix of IR led's that is built into the bezel, thei is not affected by the membrane
34by151
Finbarr1975
09-16-2023 02:52 PM
jimforrest (uk)
02-28-2019 06:42 PM
