TPMS Tire Pressuring Monitoring-Antenna C2C37077
Hi Folks,
Could someone please tell me where this antenna is located in the 2006 XJ ? Is it in the trunk area or behind the rear seat backrest? I have a situation that while the car is in motion, the "Tire pressure sensor is at Fault" does not show but when I stop, it does appear. I suspect it is either a bad initiator in the wheel well or the above mentioned antenna.
Thank you
Thank you
Clamdigger
09-09-2014 07:23 AM
