Traction
Traction
I was wondering if anyone has put wider tires on the rear of these cars. I have read almost all the article from the XF, XK and XJ. They all pretty much have the same engine, trans and weight. The only major difference is the tire size on the Xk is wider. The XJR is about .5 second slower than the XKR. Is it possible to get a 285/35/19 on a 19x8.5 rim? I think the 0-60 could drop a .5 second and keep with the XKR. The only factor I can think of that would keep the XKR faster is shorter wheel base that transfers weight better and if the rear end has a larger gear or LSD. I know my 04 with 255/40/19 can spin the wheels at 30 MPH.
